RSS-Feed anzeigen
sweet
The Best Solder For Circuit Board - How To Choose?
Bewerten
Because of the many types of solder in the market, choosing the right one can be confusing. While you are out there looking for a weld make sure you know the exact use and the type of work you are about to undertake. So how do you choose the best solder for your custom circuit board?
WellPCB knows the importance of having a solder suited to various temperature ranges and applications. Choose the best solder for circuit boards, and you'll get the electrical connections you need. But how to choose? Quickly come with me to read this article!
Name:  The Best Solder For Circuit Board0.jpg
Hits: 72
Größe:  38,1 KB
Among the key subjects on The Best Solder For Circuit Board include:
1. What is the Solder: This section provides a brief overview of the definition of Solder and the two main types of solder: The lead-based solder, The lead-free solder.
Name:  The Best Solder For Circuit Board1.jpg
Hits: 71
Größe:  21,1 KB
2.Board Best Solder Category: This section mainly introduces the three solder for the board.
They are Lead-based solders, Lead-free solders, Silver alloy solders, and the differences between the three.
3.Things to Consider When Soldering for Circuit Boards: This section focuses on three aspects of Thinking to Consider When Soldering for Circuit Boards: Wire Size, Flux, With or Without Lead.
And a detailed introduction to some problems with the use of lead-based solder.
4.Tips When Selecting the Right Solder: This section introduces how to choose the right solder from two aspects, including Diameter, Shelf Life.
And the information the two are briefly described.
We anticipate that the information shared in this article gives an overview of solders that are available in the market. You have also read about the difficulty involved in choosing the best solder for the circuit board. After reading the article to this point, you can be assured that selecting the best solder for electrical work in not as difficult as earlier thought.
WellPCB provides you with better service to meet customer needs.
Such as we need to choose the most suitable solder for your board, and rest assured that you will get good electrical connections and have a joint that will last for many years. Every item must be tested and qualified, and every detail is strictly checked. If you need PCB assembled, please contact us, we will be happy to help you.
"The Best Solder For Circuit Board - How To Choose?" bei Google speichern "The Best Solder For Circuit Board - How To Choose?" bei del.icio.us speichern "The Best Solder For Circuit Board - How To Choose?" bei Digg speichern
Stichworte: pcb, pcba, solder Stichworte bearbeiten
Kategorien
Technik
Kommentare
