ACT   sender-pult.de
Thema geschlossen
Thema: Graupner HoTT - Technisches
  1. #6181
    Heli allgemein, Einsteiger,
    Klein- und Koax-
    Freiflug, Fernsteuerungstechnik
    Kalender, Chat
    Motorflug
    Avatar von Henry Kirsch
    16.07.2008
    Berlin
    1.950
    Blog-Einträge
    2
    Sachlich/fachlich kanns nun weitergehen...
    Gewinne Bargeld.
    Kratze hier mit einer Münze und finde heraus ob Du gewonnen hast.
  2. #6182
    12.10.2003
    392
    Habe meine MC24 mit dem Hott Modul ausgerüstet gibt es da eine möglichkeit die Lautstärke der Warntöne zu erhöhen.
    GGf Piezo zusätzlich ? geht das?
  3. #6183
    08.05.2012
    Leman Lake
    28
    Standard ABOUT MC19 HOTT PLEASE
    Hello "Hotties",
    about me (did not find any welcome topic, so I do it here):
    I'm 47 years old. I live in France, close to Switzerland. I'm swiss/french.
    I started again flying in 2010. I bought a MX-16 in summer 2011. I immediatly found HOTT fantastic. With the General Air module, I was able to keep an eye to the Lipo charge during the flight, and check useful datas on my PC afterward. In november I changed my MX-16 for a MX-20. I was even more happy .
    I actually own 2 planes: a crazy Multiplex Funcub + a lovely cut E-Flite Taylorcraft, and a T-REX 500 helicopter with a waiting UH-60 Blackhawk fuselage (no 3D, scale fly only).
    Some days ago, I finally changed my MX-20 (I will put it on EBAY soon) for a MC-19 HOTT. I looked at the MC-19 for a long time, as I really love its shape, its rugged appearance, and the neck strap system. (I already switched my heli on it without any trouble).
    Yes, I lost some features, but nothing critical. I love it. I put my smartbox on it, and it's ok.
    Now I have two questions that I did not find any answer:
    - the HOTT module has 2 USB connectors. What is the USB2 for ?
    - what is the difference between the 2 channel switch 4151.2 and a simple switch ? It seems to me that the behaviour is exactly the same as an external switch 4160.1
    I understand that the 3 positions switch 4151.1 is useful as you have the center step, but is it any advantage to use the 4151.2 over 4160.1 ?
    Thanks in advance for your help, and nice flights.
    Kurodo
  4. #6184
    04.08.2002
    Kreuztal
    1.748
    Hinweis
    Ja, die Lautstärke ist eindeutig zu niedrig, aber soweit ich weiß, geht das leider nicht.
    Beste Grüße
    and always happy landings.
    Frank
  5. #6185
    04.01.2007
    Wesel - Ndrh
    54
    Hallo Mefra,
    versuche es mal mit einem anderen Ohrhörer. Ich habe diverse Ohrhörer meiner Tochter ausprobiert die gibt es mit unterschiedlichen Leistungen.
    Ich habe meine MC19 (Modul G1), Empfänger und Varios auf den neuesten Softwarestand gebracht. Reset aller Komponenten
    durchgeführt.
    Sender bindet, Servos funktionieren, Vario funktioniert. Es gibt aber keinen Menuepunkt mehr in dem ich die Varioeinstellungen
    verändern kann. Liegt es an der neuen Software das die Einstellmöglichkeit entfällt? Weis jemand Rat bevor ich bei Graupner
    anrufe.
    M.f.Gruß
    Hannes
  6. #6186
    21.02.2011
    Kirchheim unter Teck
    2.350
    Zitat Zitat von Primus0108 Beitrag anzeigen
    Hallo Mefra,
    durchgeführt.
    anrufe.
    M.f.Gruß
    Hannes
    Die mc-19 Anlage muss man auch auf V4 updaten.
  7. #6187
    21.02.2011
    2.350
    Zitat Zitat von kurodo Beitrag anzeigen
    Hello "Hotties",
    Kurodo
    USB2 has no function.
  8. #6188
    21.02.2011
    2.350
    Nein, man kann nur einen Kopfhörer verwenden.
  9. #6189
    08.05.2012
    Leman Lake
    28
    Thanks for your quick feedback. And can you help me and clarify the cases where I will have to use switch 4151.2 instead of external on/off switch 4160.1 ? I really can't see any behaviour difference when looking at the servos screen...
    Thanks in advance
    Kurodo
  10. #6190
    04.01.2007
    Wesel - Ndrh
    54
    Hallo Graupner Information,
    danke für die schnelle Antwort. Ich habe alle Empfänger GR16 mit Vers. 6.10
    Varios mit Vers. 1.18 Sender MC19 mit HOTT-Modul G1 Vers. 4.00 Upgedatet.
    Firmware Reset ist auch durchgeführt.
    Alles funktioniert. Nur bekomme ich im Telemetriemenue kein Variomenue angezeigt um irgendwelche
    Einstellungen zu machen.
    M.f.Gruß
    Hannes
  11. #6191
    04.08.2002
    Kreuztal
    1.748
    Hinweis
    M.f.Gruß
    Hannes
    Hmm, muss nicht auch das ROM auf V 4 (im Graupner Service) umgebaut werden???
    Nur die FW auf V 4 updaten reicht m.W. nicht.
    Steht so in der Versionsinfo (in der pdf-Datei), gilt zumindest so für die umgebaute mc24.
    Ansonsten wird ja noch die firmware V3 supportet, dann braucht das ROM nicht auf V4 aktualisiert werden.
    Beste Grüße
    Frank
  12. #6192
    04.01.2007
    Wesel - Ndrh
    54
    Hallo Frank,
    vieleicht Licht am Ende des Tunnels (mein Tunnel).
    Ist es richtig lt. Hott-Lounge (super gemacht) V3.
    Vario Vers.1.12
    Modul G1 Vers.1.50
    GR16 Vers.4.90
    dann werde ich mich schnellstens ans Werk machen. Danke!
    M.f.Gruß
    Hannes
  13. #6193
    21.02.2011
    2.350
    Ist das eine mc-19 oder mc-19S? Die mc-19 kann keine interne Telemetrie, nur über die Smartbox.
    Jedenfalls müssen alle Komponenten auf dem neuesten Softwarestand sein.
  14. #6194
    04.01.2007
    Wesel - Ndrh
    54
    Hallo Frank,
    Hallo GI,
    erst mal besten Dank für euere Hilfe.
    Es ist eine MC19 ifs auf Hott bei Graupner umgebaut.
    Wie gesagt habe ich mit V4 Probleme gehabt. Keine Variomenue
    in der Telemetrie. Anzeige NO Binding obwohl der Empfänger
    gebunden war. Erst nach dem die Empfängerantenne bewegt wurde
    kam die Anzeige Binding. Variodaten anzeigen mit dem Drehen des Rotary,
    kamen erst nach wiederholtem einschalten des Senders.
    Nach dem Update auf V3 funktioniert alles. Jetzt kann ich wieder fliegen gehen.
    M.f.Guß
    Hannes
    PS: Bei dem System Graupner iFS liefen die Updates mit Hilfe des Programmers
    über Funk. Der Programmer erkannte den Sender bzw. den Empfänger. Kein Ausbau,
    keine zus. Kabel. War auf jeden fall konfortabler.
  15. #6195
    08.05.2012
    Leman Lake
    28
    Standard NEW HoTT_Software_V4
    Hoho,
    I just downloaded the last version of HoTT_Software_V4.zip. It contains a great new info file: Update_HoTT_04052012.pdf. Much more easier to read than the usual Version_Information_V4_DE_EN_FR files.
    But sad for me: in this new info file the MC19 last update is referenced as version MC19U_11, and in the "Official Version\4758_mc19" directory the file is MC19U_12 ...
    Does somebody know what is new in MC19U_12 ???
    Thanks in advance for any help
    Nice flights
    Kurodo
Thema geschlossen
  1. Graupner "hott" technische Aspekte!
    Von The Hun im Forum Fernsteuerungstechnik
    Antworten: 12
    Letzter Beitrag: 31.10.2010, 09:26
Forenrechte
