Wiesel XP EPP
Meine neue gebaut Wiesel, in deutschen Farben bereit für Testflug
Cheers
Soren
90 cm Wisel maiden am 3 meter hang
1,3 meter EDF Wisel
AUW 495 gram, 40 mm DR MAD THRUST edf , 27 AMP esc, 2x Hxt900 servos, Made from normal insulator foam for houses, wing spar are 2x 1,2 mm aluminium welding rods (3 gram each), 4 mm balsa ailerons, all covered with Hobbyking covering film, plastic foam fuselage
Indoor
