Wolfgang Wallner
OpenTX 2.2.3
OpenTX 2.2.3
Hallo Reinhardt
Seit Montag ist das neue OpenTX 2.2.3 erschienen, hat das einen Einfluß auf den Konverter?
Meine Horus wird höchstwahrscheinlich bereits mit dieser Version an mich geliefert.
Das sind die Änderungen:
Main changes since 2.2.2
R9M: support for Flex firmware, clarified 1W level (auto-adjust up to 1W on current R9M firmware)
GasSuite: fix telemetry for newer firmwares (requires sensor delete and rescan)
X7/X9E/Horus: power button is now considered as a key for backlight operation
X7/X9E/Horus: allow shutdown while model notes are displayed
xlite: fix telemetry bars settings field
ARM non FrSky radios: add bindings options for XJT module
All radios with PAGE key: prevent page change during editing
FlySky telemetry : treat volts data as signed values
Crossfire/X9E: standardise wheel direction in Crossfire lua scripts
Companion: fix PREC2 telemetry data offset transfers
Companion: fix model compare switch warning for Horus (Thx Elecpower)
Companion: fix GVAR popup handling
Companion: Remove stale top bar setting for Horus
Companion: fix telem. sensor offset decimals not updating properly when precision is changed
Companion: fix file editor paste/insert actions not properly updating when clipboard data changes externally
Companion: Release notes menu item now points to the open-tx.org website
Companion: Display filename in model edit window title
Simulator: fix mixer outputs monitor not updating when channel value hasn’t change
Simulator: fix telemetry simulator A3 & A4 values not being sent properly
Simulator: fix telemetry simulator log reader parsing for “Cels(V)” column
Multiprotocol: new protocols added (thx MRC3742)
Horus bootloader: Rotary encoder operation fixed (no more need for 2 clicks per line)
Speech: Dutch added/fixed
Einen schönen Sonntag
Wolfgang
OpenTX 2.2.3
Hallo Reinhardt
Wolfgang
