Gast_68494
Gast
Like the Redundancy Bus (RB), the Redundancy Bus –10 (RB-10) has an overload protection function by PPTC through a circuit inside on each servo output. If overload current happens, the affected servo output will be disconnected from the power supply while the remaining servo outputs are still powered. Unlike the RB, RB-10 has a compact size.
Overview:
• CH1-CH8 Connect to 8 servos (PWM)
• S.PORT connect to the S.Port of X series receiver and feedback integrated S.Port values (including voltage, overload indication, etc.)
• SBUS OUT SBUS output
• RX1 IN connect to the SBUS port of X series receiver and supply power directly to the connected receiver
• RX2 IN connect to the SBUS port of X series receiver and supply power directly to the connected receiver
Features:
• Overload protection on each channel and RXS
• Dual power dual receiver double guarantee (Connect up to 2 batteries and 2 receivers)
• 50Hz mode of servo outputs (20ms period) or equal to the input of SBUS cycle
• Integrated S.Port telemetry feedbacks (including voltage, overload indication, etc.)
• Servo signal output period settable
• High voltage servos supported
• Compact size and firmware upgradable
Specifications:
• Recommended input voltage range: 4 – 8.4V
• Number of servos: up to 8
• Weight: 10g
• Dimension:63*27*10.5mm
• Operating temperature range: -20 ~ 75℃
Die RB-10 enthält keine Spannungsregelung, ist ausgelegt für 15A Dauer und 40A Peak. Jeder angeschlossene Akku sollte in der Lage sein, die genannten A-Werte allein zu liefern.
Die PPTC-Überlastsicherung soll ansprechen, wenn am jeweiligen Kanal mindestens 5A für die Dauer von 1 Minute anliegt. Hier der Link zum Manual => http://www.frsky-rc.com/download/index.php?sort=&cate_id=0&pro_id=172
Die RB-10 ist z.B. hier erhältlich, zur Zeit für 28 USD inkl. Versand => https://www.horusrc.com/en/frsky-redundancy-bus-10.html
