Copyright J'm f5mmx, France, 2018 (jmb91650@gmail.com)
This is a beerware; if you like it and if we meet some day, you can pay me a beer in return!
the MMA8451 version.
Have fun!
Changelog from I3uLL3t (m@peschi.info) V1.1
-changed the OLED Libary to U8glib becouse to lower RAM usage.
-added some F Macro´s
-changed to 128x64 SPI Oled to get more Informations on screen.
-added additional throw calculation.
-Store the Chrod to EEPROM
#include <EEPROM.h>
#include <Wire.h>
#include <Adafruit_MMA8451.h> // MMA8451 library from https://github.com/adafruit/Adafruit_MMA8451_Library
#include <Adafruit_Sensor.h> // Adafruit sensors library from https://github.com/adafruit/Adafruit_Sensor
#include <U8glib.h> // Oled u8g library from https://github.com/olikraus/u8glib
#define DELAY_DEBOUNCE 10 // Debounce delay for Push Button
#define DELAY_START_INIT 1000 // delay to start calibration when PB is pressed
const String Txt1 = "ERROR MMA"; // MMA sensor didn't start error string
// Menu text
const String Txt2 = "R Length : "; // Chord
const String Txt3 = "init in progress"; // Initializing
// Display texts
const String Txt4 = "Angle deg -->"; // Angle value
const String Txt5 = "R Length"; // Chord
const String Txt6 = "Sekant mm --->"; // Throw value milimiters
int action = 0;
bool app = false;
double corde, ref_angle;
const float pi = M_PI;
const int buttonPin = 2;
volatile int bp_pushed = 0;
volatile unsigned long bp_down = 0 ;
volatile unsigned long bp_up = 0;
volatile unsigned long bp_ = 0;
long lastDebounceTimePB_INIT = 0;
boolean lastStatePB_INIT = HIGH;
boolean triggerPB_INIT = 0;
boolean buttonStatePB_INIT = HIGH;
boolean readingPB_INIT = HIGH;
//__________________________________________________________________________________________________________________________________
//U8GLIB_SSD1306_128X64 u8g(10,8,9); //SPI
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI
Adafruit_MMA8451 mma = Adafruit_MMA8451();
double read_angle() { // Function returning the current rotation value along X axis - in degrees
double l_angle = 0;
double ll_angle = 0;
int mm = 100;
for (int nn = 1; nn <= mm; nn++) { // Average value computed over roughly 100ms
mma.read(); // Read the accelerometer values and store them in variables declared above x,y,z
l_angle = atan2(mma.y, mma.z) * 180/pi; // Compute rotation angle along X axis of accelerometer
ll_angle = ll_angle + (l_angle);
l_angle = round(ll_angle / mm * 10);
ll_angle = l_angle / 10;
return -ll_angle;
void init_angle() {
double ra = 0;
delay(200);
ra = read_angle(); // Initialize the actual angle as the reference angle
ref_angle = ra;
void EEPROMwrite(){
EEPROM.put(0,corde);
delay(300);
Serial.println(F("EEPROM UPDATED"));
EEPROMread();
void EEPROMread(){
EEPROM.get(0,corde);
void setup() {
delay(500);
Serial.begin(9600);
double temp;
EEPROM.get(0,temp);
if(isnan(temp)){
EEPROMwrite();
Serial.println(F("write"));
}else{
EEPROMread();
Serial.println(F("read"));
// Serial.println("Init done");
u8g.begin(); // Start Oled
affiche_init();
delay(100);
if (! mma.begin()) { // Try to start MMA, if fails then display error message
u8g.firstPage();
do {
u8g.setFont(u8g_font_profont12);
u8g.setPrintPos(18, 15);
u8g.print(Txt1);
} while ( u8g.nextPage() );
while (1);
mma.setRange(MMA8451_RANGE_2_G);
pinMode(buttonPin, INPUT); // define the Push Button input
init_angle();
void lecture_bp() { // Push button read function with debouncing and long push detection
int lbp = 0;
readingPB_INIT = !digitalRead(buttonPin);
triggerPB_INIT = 0;
if (readingPB_INIT != lastStatePB_INIT) lastDebounceTimePB_INIT = millis();
if ((millis() - lastDebounceTimePB_INIT) > DELAY_DEBOUNCE)
if (readingPB_INIT != buttonStatePB_INIT)
buttonStatePB_INIT = readingPB_INIT;
if (buttonStatePB_INIT == LOW)
if ((millis() - lastDebounceTimePB_INIT) < DELAY_START_INIT)
lbp = 2;
triggerPB_INIT = 1;
if (((millis() - lastDebounceTimePB_INIT) >= DELAY_START_INIT) and (buttonStatePB_INIT == HIGH)) lbp = 1;
lastStatePB_INIT = readingPB_INIT;
action = lbp;
String cnv_flt2str(float num, int car, int digit) { // Convert a float variable into a string with a specific number of digits
float tmp_num, expo;
String str = "";
switch (digit) {
case 0: expo = 1; break;
case 1: expo = 10; break;
case 2: expo = 100; break;
case 3: expo = 1000; break;
case 4: expo = 10000; break;
default: expo = 0; break;
if (expo != 0) {
str = String(int(num));
if (expo > 1) {
tmp_num = abs(num) - int(abs(num));
str = str + "." + String(int(tmp_num * expo));
while (str.length() < car) {
str = " " + str;
return str;
void aff_menu() {
int action = 0, l_pas = 1;
double l_ang = 0, l_act = 0, l_posi = 0, l_ref = 0;
u8g.firstPage(); // Display values
do {
u8g.setPrintPos(5, 15);
//u8g.print(Txt2 + cnv_flt2str(corde, 4, 1) + "mm");
u8g.print(F("Rud. Length :"));u8g.print(cnv_flt2str(corde, 4, 1));u8g.print(F("mm"));
u8g.drawBox(64 - 7, 22, 14, 10);
u8g.drawFrame(64 - 20, 22, 40, 10);
u8g.drawFrame(64 - 45, 22, 90, 10);
u8g.drawFrame(0, 22, 128, 10);
u8g.setFont(u8g_font_4x6);
u8g.setPrintPos(64 - 1, 30);
u8g.print(F("0"));
u8g.setPrintPos(64 - 19, 30);
u8g.print(F("-.1"));
u8g.setPrintPos(64 - 45 + 12, 30);
u8g.print(F("-1"));
u8g.setPrintPos(64 - 63 + 5, 30);
u8g.print(F("-10"));
u8g.setPrintPos(64 + 19 - 9, 30);
u8g.print(F(".1"));
u8g.setPrintPos(64 + 45 - 14, 30);
u8g.print(F("1"));
u8g.setPrintPos(64 + 63 - 14, 30);
u8g.print(F("10"));
do {
delay(10);
lecture_bp();
} while (triggerPB_INIT != 1);
delay(50);
l_ref = read_angle();
do {
l_ang = read_angle() - l_ref; // read current angle
if (abs(l_ang) >= 7) { // If angle over 7 degrees
if (abs(l_ang) < 20) {
l_act = 0.1;
else {
if (abs(l_ang) < 45) l_act = 1;
else {
l_act = 10;
if (l_ang > 0) l_pas = 1; else l_pas = -1;
else l_act = 0;
// Serial.println("angle :" + String(abs(ang)) + " act " + String(act));
if (l_act != 0) {
corde = corde + (l_act * l_pas);
l_posi = l_ang;
if (l_posi >= 64) {
l_posi = 64;
else {
if (l_posi < -64) {
l_posi = -64;
l_pas = 64 + l_posi;
do {
u8g.print(F("0"));
u8g.print(F("-1"));
u8g.print(F(".1"));
u8g.print(F("1"));
u8g.print(F("10"));
u8g.drawLine(l_pas, 18, l_pas, 34);
u8g.drawLine(l_pas - 1, 18, l_pas - 1, 20);
u8g.drawLine(l_pas + 1, 18, l_pas + 1, 20);
delay(20);
lecture_bp();
// Serial.println(triggerPB_INIT);
action = 0;
void affiche_init() {
do {
u8g.setFont(u8g_font_7x14);
u8g.setPrintPos(5, 24);
u8g.print(Txt3);
void affiche(String l_angle, String l_corde, String l_debat, float r_angle,String l_throw) {
do {
u8g.setPrintPos(1, 14);
u8g.print(F("Angle deg. -->"));
u8g.setFont(u8g_font_7x14B);
u8g.setPrintPos(80, 15);
u8g.print(l_angle);
u8g.setPrintPos(1, 26);
u8g.print(F("R Length "));u8g.print(l_corde);u8g.print(F("mm"));
// u8g.print("Corde " + l_corde + "mm");
u8g.setPrintPos(1, 38);
u8g.print(F("Secant mm--->"));
u8g.setPrintPos(80, 39);
u8g.print(l_debat);
u8g.setPrintPos(1, 50);
u8g.print(F("Throw mm--->"));
u8g.setPrintPos(80, 51);
u8g.print(l_throw);
void loop() { // Main loop
float x_rot = 0, aff_angle = 0, angle = 0, debat = 0;
float throww = 0;
int act = 0;
lecture_bp();
switch (action) {
case (1):
aff_menu();
affiche_init();
init_angle();
action = 2;
break;
case (2):
affiche_init();
init_angle();
EEPROMwrite();
action = 0;
break;
default:
break;
x_rot = read_angle(); // read current angle
x_rot = ref_angle - x_rot; // compute angle variation vs. reference angle
angle = (x_rot / 180) * pi; // angle value converted into radian
// Serial.println("angle :" + String(angle));
throww = sin(abs(angle));
throww = throww * corde;
throww = abs(throww);
debat = sqrt(2 * sq(corde) - (2 * sq(corde) * cos(angle))); // throw computation in same units as chord
//affiche(cnv_flt2str(x_rot, 6, 1), cnv_flt2str(corde, 4, 1), cnv_flt2str(debat, 6, 1));
affiche(cnv_flt2str(x_rot, 6, 1), cnv_flt2str(corde, 4, 1), cnv_flt2str(debat, 6, 1),x_rot,cnv_flt2str(throww, 6, 1));
