Mig 15 1/4 scale
eug
Hi Mugurel
Nice Job. I will try to make molds for a Messerschmitt Me P1112, as you can see on my webpage. These days, I am drawing the cross sections for the fuselage. Later I will build the positive model for the negative molds.
Regards,
Chris
Nice ! I can not see the photos with the work ! You have some photos with you master ?😊Thanks
Hi Mugurel
Regards,
Chris
Sorry ! 😬😜now i see you are drawing now you model !!!
Nice plane !
Thoemse
Schaut echt super aus, was du da machst. Die Vorlage finde ich ein unheimlich interessanten Flieger. In der Größe und alles im Eigenbau - Respekt.
Ich wünsche weiterhin viel Erfolg.
eug
thanks
thanks
Nice plane !
Mugurel,
which wing profile are you using? Will you put any twist towards the outer span?
I will most probably use a NACA 2412 with -2 degrees twist towards the outer span.
Chris
Roli14
Was ist das Pinke Zeug für eine Masse, die Du zum Verspachteln der Übergänge genommen hast?
Gruß Roland
LOOKS ABSOLUTELY STUNNING :eek::eek::eek:
love your metalwork... Such a level of structural detail is exactly what a Jet like the Mig 15 needs! Absolutely great work!!! Keep it up;)
Best regards
David
