hello I would like to introduce you the Vettore Glider a New 4 meter allround glider
the main features are the thermal and acro in the same time, Made by Voloinpendio.it staff and in co-operation with our friend Giuseppe Ghisleri.
the Vettore was presented at International Meeting Monte Cucco 2018 and Segelflugmesse 2018, was a great success and have surprised all the participants, with fantastic Thermal and acro performance.
This glider is distributed in Germany from Edi's ModellbauParadies or Switzerland from Leomotion.
it's produced in 3 versions
OD (fiberglass + reinfoced and Carbon spar ) Standard
FS (full Carbon wings) very strong
ODLight (fiberglass + reinfoced and Carbon spar) in light version under 5kg in odv.
below you can Find all information:
wingspan 400 cm
weight order of flight: 4.9 kg in Light Version , 5.1kg in OD version , 5.4kg in FS version
wingload from 55gr/dm2 to 65gr/dm2
The kit includes (all composites parts are painted directly in the mold):
- Fuselage (fiberglass + carbon reinforced)
- wings (carbon/fiberglass), aileron hinged on top, flap hinged on down
- wing joiner all carbon 40*16 mm
- tailplane (fiberglass + carbon reinforced)
- rudder (fiberglass + carbon reinforced)
- canopy pvc
- cockpit (fiberglass)
the Vettore is produced in Line white line, Basic line, Deluxe Line)
-White Line: are intended models with only white paint (up/down)
-Basic Line: are intended models painted with 2 different colors (you can choice the colors; yellow, black, blue, red, green, white, orange)
-Deluxe Line: since 2019 , in deluxe kit you will find the fuselage repainted in the junction line ,only available in standard colors, not fluo or Carbon see trough
Below you can find a our small clip ( from smartphone) of maiden flight of prototype in a small hill with a 50meter of slope
Video of the flight in Monte Cucco Meeting 2018
video of the flight in Segelflugmesse 2018
https://www.facebook.com/241433796410002/videos/273887956497919/
ciao Giammarco
wingspan 400 cm
- canopy pvc
ciao Giammarco
