Gast_68494
Gast
Introduction
The Gas Suit is a multifunctional kit which is mainly used to monitor the operating state of a gasoline engine for a model. You can measure the real-time working temperature and RPM, flow velocity of gasoline,and then the measured data could be transmitted back to your receiver through the Smart Port (S.Port). Last but also important function is people can control the ignition system manually, let you have a freedom control during your operation.
Specifications
Weight:19g
Dimension: 40*28.8*12.7mm (L*W*H)
OperatingVoltage Range: 4.0V~10V
Measured Range of Speed: 100~100000r/min (Degree of Accuracy: ±2%)
Measured Range of Flow Velocity: 20~800ml/min (Degree of Accuracy: ±2%)
Measured range of temperature:
- TEMP1: PT100: -20℃~ 310℃, Degree of accuracy: ±1%
- TEMP2: NTC: -20℃~ 250℃, Degree of accuracy: ±1%
Physical interface: Temp1 & 2, FLOW, CDI pulse In & Out, Channel In, Smart Port
Features
Monitor the real-time environment temperature and operating temperature of the engine.
Monitor the real-time RPM and the gas flow velocity
Smart Port enabled and support telemetry data transmission
Enable and disable the ignition control system manually
Parameters (Initial quantity of gas, alarm values and etc. ) configuration through transmitters and FreeLink (PC)
More details link : https://www.frsky-rc.com/product/gas-suit/
