Onkel Google ist dein Freund:
BALANCING
1. It is critical that your airplane be balanced correctly.
Improper balance will cause your plane to lose
control and crash.
THE CENTER OF GRAVITY IS LOCATED 175mm
BACK FROM THE LEADING EDGE OF THE WING,
AT THE FUSELAGE.
2. Mount the wing to the fuselage. Using a couple of
pieces of masking tape, place them on the top side of
the wing 175mm back from the leading edge, at the
fuselage sides.
3. Turn the airplane upside down. Place your fingers on
the masking tape and carefully lift the plane .
4. If the nose of the plane falls, the plane is heavy nose.
To correct this first move the battery pack further
back in the fuselage. If this is not possible or does not
correct it, stick small amounts of lead weight on the
fuselage under the horizontal stabilizer. If the tail of
the plane falls, the plane is tail heavy. To correct this,
move the battery and receiver forward or if this is not
possible, stick weight into the firewall. When balanced
correctly, the airplane should sit level or slightly nose
down when you lift it up with your fingers.
Gruß, Peter
