DFS Kranich 1/6 3m Wingspan
Hi everyone, I back to update some photos recently. My friend still haven't finished the fiberglass fuselage, So I build the second one during the virus block down, I prefer to vintage silk covering.
Firstly I using filler handle the gaps, and the connected part between the wings and fuselage
Oil painting tools are very suitable for scraping filler, haha
Dope. (The label says Q63-1 Nitro Coating Paint, Because there is no models Dope in our market, I found Dope for real aircraft. This paint is used for painting the rudder surface of the AN-2 biplane.)I thin it with thinner, the volume ratio is paint:thinner 1:2
silk. We have it easily available here, I chose the classic tawny, but there are also white, cream and darker tans. Its specification is about 7-17g/㎡, the ductility is very good, and it is very easy to handle the spherical surface. I think its ductility is greater than that of glass fiber, so that I only used 4 small pieces of silk for the whole body (including covering the complex machine. wing root)
After two coats, the texture of the cloth is still obvious. I decided to keep this color as the color of the plane. The splice of the silk will become less and less noticeable over time (as the overall color will get darker and older over time)
This picture is after the first coat, and it can be seen that the splice of the fabric is still obvious in the picture.
I painted this part gray. As pictured, the canopies has also been secured with very small clockwork screws
And then paint the nose to red. The white tape is Tamiya curved masking tape.
For silk surfaces, I recommend applying water-based paint with a pen as much as possible. If you spray paint, because of this Dope process, even if you paint the dope many times, it is still difficult to avoid small pinholes on the surface. This can cause some trouble when painting.
Looks very cute
SirToby
Is the dihedral korrekt? I've found two sketches in the web:
