Dutch RC Kits Eurofighter.
Berto
Top side covered:
Wing tube stop from scrap:
Filled gear plate with balsa:
Right wing ready for covering:
Servo installation:
And bottom side covered:
Ready for installing the leading edge this evening:
After sanding the wings will be glassed and painted so they will be ready for the static model in the booth at JetPower.
Ray66
Hi Tom,
Kann man machen aber für JP etwas zu wenig zeit.
Ray66
Berto am arbeit.
Nach aushärtung, einer zweite lage epoxy.
Endresultat zusehen auf dem JetPower.
Berto
With a simple wire strut determined the requested length for the home made trailing link legs:
Seems all with fit nicely with the CMjets tank in front of the K70:
Mine version will get a single pipe, Ray`s will get vector thrust. But also enough space for a twin pipe:
'Bridge' for stifness there the wingtube can not be in one piece:
Berto
2 liter fuel tank, fits in this Eurofighter and Dutch RC Kits F-86 Sabre:
Fuel tank mounting:
'Bridge':
Making a battery plate which will slide in the nose:
Perfect fit with the Grumania Jets pipe:
Looks like a Eurofighter:
Wing tubes glued in the wing and wing mounting:
Nose wheel steering servo sits above the retract unit:
RSED-RC 6 pins wing connector for the servo and gear:
Plastic servo arm replaced by a aluminium version which is 100% better:
Electron ER-30eVo`s installed:
Had the Eurofighter on the scale and without fuel it will be just about 5Kg, with 2 ltr of fuel it will be close to 7kg so 1:1 thrust:weight ratio :D
Berto
Legs are made at Dutch RC Kits with Ray.
First milling set, we made some changes after this one:
Looking good:
And for the first time on his own gear:
Plate for the turbine hardware and Electron controller, this will slide below the canards plate:
https://www.remotejets.com/projects/Eurofighter/Eurofighter%20%2887%29.jpg[/iIMG]
[IMG]https://www.remotejets.com/projects/Eurofighter/Eurofighter%20%2888%29.jpg[/iIMG]
Think mine will get this sheme after the first few flights:
[IMG]https://image.jimcdn.com/app/cms/image/transf/dimension=670x10000:format=jpg/path/s9f2f72686a9d0864/image/i838297342aeed34e/version/1523864275/image.jpg
Maiden is not far away anymore :-)
Ray66
Angefange mit 2019 Display plane für Luuk Struik. Werd geflogen mit K70 und vector steurung. Presentierd auf Prowing 2019.
Resultat nach einer stunde arbeit.
