Eine preiswetre Alternative zur MM und Fortune...
MINI BLACKHAWK
Patterned after our own Blackhawk 32, this scaled down version is a fast boat and sails exceptionally well. In fact, it's compact size allows it to even be sailed in a small pond or swimming pool. A simple two channel radio is all that is needed to get started with this great boat.
This kit is easy to build and makes a great starter kit for the first time sailor. If you are looking for a beginner boat to introduce your children to sailing, you can't go wrong with the Blackhawk 24. This kit has a molded Hi-Impact black plastic hull and molded white plastic deck trimmed and ready for assembly. A complete hardware package, finished white Nylon sails, pre-assembled keel bulb, and an ample amount of lead shot for ballast make assembly fast and easy. Select wood parts, marine plywood keel fin, complete decal set and easy to follow instructions complete this fun boat.
Kit Price: $59.95
Specs:
Length: 24" Beam: 5.5
Height: 41" (approx) Keel Depth: 8" (approx)
Sail Area: 230" sq. Weight: 2.5
MINI AMERICA³
This is a 24 inch version of the beautiful racing yacht and 1992 winner of the Americas Cup, The Mini America³. Designed for easy construction and can be sailed in small ponds or even swimming pools. A simple two channel radio is all that is needed to get started with this great boat.
This kit is easy to build and makes a great starter kit for the first time sailor. If you are looking for a beginner boat to introduce your children to sailing, like our Blackhawk 24, you can't go wrong with the Mini America³. This kit has a molded Hi-Impact plastic hull and molded white plastic deck trimmed and ready for assembly. A complete hardware package, finished white Nylon sails, pre-assembled keel bulb, and an ample amount of lead shot for ballast make assembly fast and easy. Select wood parts, marine plywood keel fin, complete decal set and easy to follow instructions complete this fun boat.
Kit Price: 59.95 $
Specs:
Sail Area: 230" sq. Weight: 2.5 lbs.
Quelle
Die Modelle dort sind überhaupt preiswert, das problem ist halt der versand
[ 14. Februar 2004, 08:33: Beitrag editiert von: Eric ]
Gast_3462
die Seite und Boot habe ich auch schon mal "verschlungen". Mein Hauptinteresse lag bei diesem Schiffchen Íl Moro .
Ich habe auch schon angefragt zwecks Versandkosten, dies war die Antwort:
Hello Alf,
Thank you for your interest in our IL Moro kit.
We can send the kit to Germany by Air Mail Parcel post.
It can send with or without lead shot (5 lbs #9 size required)
Shipping charges are $42.85 with shot or $31.25 without.
Happy Sailing,
George Dornis
Finde ich eigentlich ganz verträglich, wir können ja einen Import-Handel aufmachen. :D
Alf
[ 14. Februar 2004, 16:01: Beitrag editiert von: ab ]
seb
Hallo , Danke für den Link, aber so richtig kann
ich die US- Bausätze nicht empfehlen.
Dauert Extrem lange bis sich der Deutsche Zoll
mal meldet und Zoll kostet auch richtig.
Die Rümpfe sind aus schwabel ABS , die Kielflosse
aus Sperrholz und die Deck-Rumpfverbindung passt
auch nicht so schön. Nach dem öfter gehörten
Bastelst du noch , oder segelst du schon empfehle
ich die Fortune 612. Ist auch so schön handlich !
Gruß seb
