Jim Caldwell
After watching all the available foiling videos, I wonder;
1 Most of the foiling video attempts, when they look like they should have the speed, end up pitch poling.
Looks like the foil lift is too far aft. Why not move them forward?
2 Hulls are not lifting up on the foils until 8 to 10 knots, why not increase the cord to say 8mm, it will increase the drag and lower cavitation speed, but we are nowhere near cavitation speed and lower take off speed to 5 to 6 knots?
3 Most of the V foil boats have heave problems and the one that doesn't has spent a looong time getting it to work in a narrow range. Since the V foils generally have the foil shaft going thru the hull with a stub sticking out, why not install the Bradford Ride height control system because it would be an easy mod?
https://docs.google.com/viewer?a=v&...WFpbnxoeWRyb3NhaWx8Z3g6NjU0NDdkNmI0ZDFmOGM2ZA
