Good way to Remove scorpion stators
stolla
Hi guys, just a quick one on how i find best way to remove a stator from a scorpion and probably other motors as well since i did a lot of damage trying to hammer it out.
The best way is to use the motor mounting holes and then take some long screws of the same thread, screw them in from the outside then place a shim between the stator and the screws, slowly turn in the screws in equal amounts to keep the stator straight as you push it out of the housing. Very easy without damage to the stator
Regards
