Jetcat
Jetcat
Hallo Lavy!
Calibrate the temperature probe.
To compensate the differences from engine to engine there is an offset number that is used to correct the temperature displayed. This offset is derived by sampling the actual temperature read from the engine compared to the ambient room temperature.
Your engine should be at approximately room temperature, 21 °C.
Press and hold the Select Menu key on the GSU, then switch on the power.
�� Remark:
Instead of pressing the Select Menu key on the GSU, the little key on the LED board can be use instead.
The three LED´s first show the following blinking sequence:
LED Blink Sequence Standby/Man. Yellow �� �� �� �� �� ��
Pump running Red �� �� �� �� �� �� �� �� �� �� ��
OK Green �� �� �� �� �� �� ....
The Display of the GSU will also show the message:
Release key to:
- learn RC -
Keep the Select Menu key pressed during this blinking sequence. It takes up to 10 seconds!
Only release the key when the 3 LED´s are showing the following sequence:
LED Blinking sequence Standby Yellow �� �� �� �� �� ��
Pump running Red �� �� �� �� �� �� �� �� �� �� �� ��
The Display of the GSU will change to the message:
Release key to:
Calibrate Temp
�� now release the key
• The display should return to the default showing RPM and temperature. The temperature should be 21 °C.
Viel erfolg!
Grusse, Henk
