Radiomaster TX16S MK3
Bei den nächsten Chargen der TX15 und TX16 MK3 wird der interne Speicher von 4GB auf 512KB gekürzt!!
Nachricht kam heute direkt von Radiomaster.
Wenn man bei der TX16 MK3 max die Rasterung aktiviert, verliert man einiges an Weg, nach erneuten Kalibrierung sind es dann wieder 100%.
Kennt man den Grund? Ich kann mir Komponenten-Preise/Verfügbarkeit vorstellen, vielleicht gibt es ja aber auch technische Gründe? 512MB wird mit vielen Log Files irgendwann eng :(
Siehe Facebook, RM Post:
🎮 RadioMaster TX15 / TX16S MK3 - Memory Configuration Adjustment
Due to ongoing global flash memory supply issues, a hardware adjustment is required to maintain consistent production and availability of the TX15 and TX16s MK3.
Unfortunately, 512MB flash chips now cost more than 4GB chips did just a few months ago. The greater issue, however, is that there is currently no guaranteed supply of the 4GB chips, which means production could stop at any time.
After careful consideration, we have decided to switch to the 512MB chip, because its supply is currently stable. We will absorb the increased cost to avoid raising the retail price of the TX15 and TX16s MK3.
🎯 What's Changing:
- 4GB inventory is now in limited supply, both on our official website and across our dealer network. When the 4GB stock runs out, an announcement will follow, and our website details will be updated to show the 512MB version in stock.
- Orders placed before the announcement will ship with 4GB flash, including all TX16S MK3 pre-orders.
- No price increase — additional costs are being absorbed by RadioMaster
- This change ensures a stable supply and avoids production delays
❤️ This adjustment is necessary given current supply chain conditions. The updated 512MB internal flash remains sufficient for normal operation, including model storage, firmware updates, and all core functions. There is no impact on flight performance. Both radios also support external SD cards for applications requiring additional storage.
🌹 We apologize for this unforeseen issue and believe we have made the best choice we could in this situation, and thank you for your understanding.
Moin,Moin
Meine Max ist seit gestern auch angekommen, das Problem mit der Schraube habe ich auch gleich festgestellt 😥 Ich habe die dann durch eine sehr kurze Madenschraube ersetzt.
Ansonsten ist das schon ein sehr schöner Sender.
Wo ich gerade schreibe, welche Dateien muss ich von der Radiomaster TX16S zur MK3 kopieren wenn ich meine Modelle möglichst nicht neu Programmieren möchte?
Ach ja ist eine MAX Blau
Gruß Walther
Guten Morgen Walther,
Ich habe die Images kopiert und den Model Ordner. Danach sollten die Modelle da sein man muss aber danach bei jedem Modell die ELRS TX Einstellungen neu setzen (also z.B. 333Hz Full). Da standen bei mir bei jedem Modell irgendwas mit 200 drin. Und den Switch Mode ggf. anpassen.
Manfred
Diese Daten werden ja auch im ELRS Sendemodul abgelegt. Über das Web-Frontend kannst Du diese Einstellungen sichern und auf den neuen Sender übertragen
Ich habe meine Daten von der HelloRadioSky V16 zur TX16S MK3 übertragen. Da die TX16S ja ein anderes HF Modul (Dual) nutzt würde ich die Einstellungen grundsätzlich pro Modell überprüfen.
Z.B. nutze ich auch Modellmatch. Die Empfänger ID wurde korrekt übertragen stand aber bei jedem Modell auf OFF anstatt auf ON.
Aber mir war nicht bekannt das man die Einstellungen Exportieren und Importieren kann. Ich habe einfachen manuellen Filetransfer gemacht.
So aus Interesse, hat die MK3 noch die Anschlußmöglichkeitfür zusaätzliche Geber?
Meine MK0 kann noch mit 2*Poti und 2*Schalter aufgerüstet werden.
Ja, wie bei der alten: 2 Potis und 2 Schalter können direkt angeschlossen werden. Ansonsten hast Du noch 2 freie serielle Schnittstellen.
Servus Zusammen,
Ich überlege gerade eine TX16S MK3 MAX anzuschaffen.
Ich habe ein wenig bedenken, dass es nur die FCC Version gibt, zumindest auf der Radiomaster Webseite kann man die LBT Version nicht auswählen.
So weit ich weis, ist die FCC in der EU offiziell nicht erlaubt ...
Kann mich da jemand auf Stand bringen?
besten Dank!
Servus Zusammen,
besten Dank!
Die HW ist immer dieselbe: nach Erhalt auf ELRS V4 EU-LBT umflashen / updaten.
In deinem Land. Lohnt sich nicht, das bei Ali und Konsorten zu bestellen. In DE zum Beispiel bei Rotorama.
Grüsse Florian
Ich bestelle am liebsten bei RC-Hangar15, die sind wohl auch Distributor für Radiomaster. Rotorama in Tschechien nutze ich auch gerne.
Hab in Tschechien meine MAX bestellt da stand LBT Version und ich habe von dort auch die LBT Version mit EU868 bekommen.
Also 2,4 Ghz und 868 Mhz ist ja Dualsystem.
Ich hätte also nichts Flashen müssen wenn ich auf BindingPhrase verzichtet hätte.
Meine kam aber von einem anderen Shop der hier letzte Woche gepostet wurde.
Manfred
