Scorpion 3226 1400kv
Hi i have a Scorpion 3226 1400kv damaged from a crash with a rcrcm F5d Falcon.
I see 2-3 broken wire in the central phase may be a problem or i can use it?
The motor run normally without propeller...
you can use it but have allways a closer look after runninit. As the brocken wire are very close to the and of the strand , there are only some millimeters to the soldering spot on the esc. you can solder all the wires at this point together. Than all the wire will be conectet and carry the amps at the lowest resistance.
Happy Amps Christian
