umulius_dk
Hello everyone
I need some advice. I would like to buy a Sebart Avanti XS, Aermacchi mb339 XS or Black Horse Viper Jet. All 120 mm edf. I cannot fly with real jet turbine at my field.
Do any of you have some advice regarding these planes? I plan to buy 12s Schubeler 120 mm edf DS-86-AXI hds with het motor. I suppose that is the setup recommended at many dealers.
But is is sufficient power?
I have read at rcgroups that some discuss too little airflow for the fan. Is it true or does it have the right power? I will not cut out wood of the plane in order to make it get the right flow of air. If I have to, I will buy something else:-)
Best regards
Peter, Denmark
Best regards
Peter, Denmark
