Skywing Edge 540 91': electric is better!
August is over and we are back from vacation. I had interrupted my review talking about the firmware upgrade of the ZTW Esc to optimize it at its best with the Dualsky DA6000 engine. And from here I resume talking today about the choice of batteries that are the "fuel" of the electric engine. Today I want to focus on another fundamental aspect for the setup of a maxi model converted with an electric engine: the batteries. The choice of power supply can be subjective with regard to how many cells to use, their amperage or the brand but there is one thing that cannot be compromised, that is the quality of the battery chemistry. Unfortunately I also fell into youthful (and inexperienced) mistakes with the first electric models (both propeller and fan) but all this helped me understand that saving on this aspect is not always a good choice. Obviously the truth is always in the middle because if it is true that batteries of brands that have long been known and appreciated by even professional modelers sometimes the cost does not justify the advantages; as it is also true that low-cost batteries are often poor in terms of performance (especially if subjected to stress such as in electric fans).
And since I like to experiment (I have tried so many batteries) I took advantage of the purchase of the Dualsky GA6000 motor to also try the LiPo Dualsky G7 HED series, where HED stands for High Energy Density. The 6S 5800Mah packs measure 158x45x51mm for a weight of 774 grams.
These cells, according to the data provided by Dualsky, thanks to continuous updates (they are now in their 7th generation) manage to be not only high-performance but also lighter and more powerful (in fact they weigh about 50 grams less than other similar packs). They have a continuous discharge capacity of 45C with high dynamic performance that guarantees over 300 charge/discharge cycles without evident loss of capacity. Interesting that Dualsky worked with Xpower to be able to obtain the advantage of having an optimized discharge voltage in the low capacity phase which translates into Greater Power even with reduced capacity residues; it is in fact known that often in LiPos there are drops in Power with the decrease in battery amperages.
The Dualsky G7 HED LiPos arrive with the pre-soldered XT60 blue plug, but this could be irrelevant for those who use other types of plugs. Finally, in terms of quality, Dualsky batteries are scrupulously inspected before shipping to the Shanghai factory.
However, given the not excessive absorption of the motor which with the 24x10 propeller should require 100% Power of about 100 amps, these batteries should not be stressed. But I would not go below 5500 mha of capacity for any battery you decide to use.
Guten Abend,
Dies ist der Motor, den ich GA6000.9/160kv gekauft und in meinen Bushmaster 120 eingebaut habe ...
Ich erwarte nächste Woche den IBEX 220 Controller. Ich hatte es bereits mit einem 200-A-Jeti und einem Falcon-Carbon-Thermopropeller versucht und hatte am Boden etwa 90 A...
Ich bin daher eher auf der Suche nach einem Xoar PJN-Elektropropeller in 24x12 oder 25x12, aber sehr schwer zu finden, weil ich ihn auf Ecalc mit den richtigen Parametern 105 und 120 A und etwa 17-18 kg Traktion gefunden habe (dasselbe gilt für das US-Forum der RC-Gruppen). ).
Fortgesetzt werden.
Ich gebe an, dass ich kein 3D machen werde.
Wie sind die Erfahrungen bisher mit dieser Kombination?
fliege den GA6000/9 mit Hobbywing 200 und xoar 24x12 mit 5000er 14S in einer ExtremFlight Extra 330 91“ absolut unauffällig mit toller Leistung und alles schön kühl. Natürlich nicht dauervollgas!
