Stingray 3.5m by Piero Brussolo Buil Log
Hallo everybody,
I’m not new in the forum, but this is my first build tread.
First of all I’m really sorry to write in English, but my German is not so good to self-explain in a satisfactory way (ich kann ein bischen Deutsch aber English is sehr einfacher für mich!!!).
I’ll write then this build log in English but I’m happy if someone have some questions or observations in German, I’ll translate and answer.
But let’s come to the point …
after I had seen a tread opened by Giuseppe Ghisleri on RC Network on a Stingray produced in Italy, I decided to contact Mr. Piero Brussolo for information on his 3.5m Stingray (it was beginning of 2020).
It ended that a few days ago I collected everything (with some delay due to Corona Virus and possibility to go in Italy)
But let's go in order.
Here is the tread from where it all started:
You can find many pictures and explanations from Piero on his product and his production technique.
You can also find Piero's contacts, in case you are interested in more details (info@modelleriabrussolo.com)
Below you will also find some more images and some videos that give the idea of what kind of product we are talking about.
In Germany the product can be found here:
It's a relatively new product and not much is out there, so I decided to do a build log.
Maybe someone will find it useful, both to have a little more information on the product and a little guidance in its construction (don't get me wrong please ... I don't claim to teach anyone ... quite the contrary)
It will take me a while to put it together because I have other works in progress, but slowly we will proceed, most likely during the autumn.
The product:
- all fiber
- lots of carbon (almost everything)
- Kevlar and glass at the front of the fuselage for obvious reasons of radio transmissibility
- a nice square carbon joiner
- full mobile elevator on ball bearings
- various small parts to glue inside to place servos and radio system
- a precision of construction, which at first glance seems truly excellent
- out-of-mold painting covering all construction joints
- in my case a rather particular colour that made Piero a little crazy .. but in the end he succeeded
- nice bags for joiner, wings, fuselage and elevator
Well there are many things to say and in the next few days I will post more detailed photos of the kit with a little description.
Meanwhile, a preview below.
See you soon,
Andrea
Here is some detail of the fuselage.
Step by step I'll describe all the kit...just need a bit of time.
View of the Fuselage in its entirety
Detail of the canopy and its support (to be painted and glued together)
Piero works as much as possible with his CNC, and below you can see the side holes that will be used to fix the canopy itself, using a 2mm wire that slides inside a brass sheath (supplied in the kit)
Under the wing karman; everything you see is milled with great precision.
Consider that the joiner is not floating, but is inserted (very precise) and with the hole for the rear centering pin, it holds the wing in position
The front longitudinal drilling is used for fixing the wings, while on the rear you can also see the housing for the connector of the wing servos
Under the elevator area
The elevator is mounted on two bearings, which Piero has already placed in position
The alignment with the wings is perfect
The small 1mm hole you see in the photo below is also machined and indicates the center of the cut from which the pull-pull wire must come out for rudder control
On the left of the tail, the hatch to insert the elevator servo (the cover of the same color as the spindle is clearly provided in the kit)
The rudder is entangled in the lower part, while in the upper part it is hinged with a 2mm steel wire which is inserted from the top
Let's finish with a photo of the inside of the fuselage. Nice, clean, and finished very well
You can see the front in fiberglass and the rear all in carbon
That's enough for today.
We will continue in the next few days by describing the wings.
See you soon,
Andrea
graefi
Thank you Piero for the information, so that finish comes after the pieces are out of the mould.
Hallo everybody,
sorry for disapperaing for a bit, but I'm very busy with other projects and with my job!
Here below some picture and description of the wings.
Well, the Stingray wing is something I really like.
This trailing edge profile is very elegant and what intrigues me most about the model.
Below a photo of the two wings
On the lower part I asked Piero to leave unpainted strips, to avoid putting stickers and increase visibility in flight
The upper part is one color and I will put some adhesive to break the nice orange
All moving parts are equipped with a lip, to improve aerodynamics during movement and avoid abrupt changes in profile and edges or gaps
All moving parts are hinged on the top. The commands will be below.
The wings are held together by this brick
Interesting that the brick is not a simple parallelepiped but it is conical so as to reduce the play to a minimum when tightened in the wings (nice idea; you have to be precise to do a job like this, but it seems that Piero can!)
Below is a detail of the area that joins with the Karman
A rear anti-rotation pin and a simple but effective eyelet on the front to hold the wings together (spring, elastic, strap as desired)
The trailing edges are pretty sharp, certainly not like those of my Sprite from the Valdimir Model, but the model has to resist even a few hits on the slope, so a minimum of strength is needed. In short, much better than many famous brands that are on the market (some of which I have in the cellar!)
Finally the elevator.
12mm carbon axle and 3mm steel rear axle ... all quite strong!
Coming soon description of bags and internal small parts.
See you soon,
Andrea
PS: I confirm that painting is out of the mold
Hallo everybody,
sorry for the long time off but I was busy and struggled to log and post some more picture.
Anyway, as promised here below you can find the protection that Piero can provide with the model.
Fuselage, wings, wing joiner and elevator.
The solution of having wing joiner and elevator together with the wings is quite nice and practical. In case you can detouch the parts (also very nice)
See you soon,
Andrea
And here some of the parts that Piero gives together with the kit, including internal wood parts, movable parts horns, some maks §D printed to position connectors in the wings.
The wood parts include:
- front rib that it is used to secure the canopy on the front and to have a nice separated compartment where to put some weight when needed
- double central rib, to be glued just behind the canopy
- rear rib and rudder servo support: this is especially designed to be positioned behind the wings so that it leaves space to the bottle for water ballast (recommended by Piero if you want to have high performance in very strong conditions). this is made in such a way you mount the servo on its holder and you screw it on the rib (quick and nice)
- finally there is the wood plate for the electronics
Work will start soon 🙂
Ciao,
Andrea
So.... some details of the work in progress.
First thing to do is to glue together the two big ribs and the three long pieces that will be used to support the electronics plate and to strenght the fuselage (although I must admit this is the stronger fuselage I have had in my hands.
The other thing I like to do, before installing all weeods parts in the fuse, is to cover them with black glass fiber. You can find this in R&G, it is quite cheap and gives a very nice looking results. I'm used to do that in all my airplanes. Once finished it is very nice to see.
Someone qill say "yes but it is inside...so nobody see it!"...well, I see it anytime I open the canopy 🙂
You will see the results at the end, it is quite nice
Ciao,
Andrea
We move forward...
Preparation of rudder servo support
I cut a bit more the original part in a way that I can also fit them together not only on the surface.
On the span that has to be glued on the fuselage I put wood self locking nuts (they are used to fix and remove the servo support)
Regarding the electronics plate, Piero suggests to glue it directly in the fuselage.
Me, I like to be able to remove this part and to use also the space below... so, I decided to cut a small frame that I'll glue on the fuselage and on which I'll screw the electronics plate
Ciao,
Andrea
