Thomas Kolben pumpe -EMC-Vega.
I`ve been looking at the vakuum pump that EMC-Vega sells. It comes in two versions, one single, and one double. I`ve been looking at the single one. Does anyone here have any experience with it? Whats your setup?
-Do you use it continously, or with a switch?
-How much vakuum can you pull?
Sorry that I don`t write German. You may answer in German, as I usually:confused: manage to read it..
Mfg.
Kjell.
Wow, Christian, your setup looks really nice. I`m using a pump setup from ACP- composites in USA, but it only pulls -0,6 bar, and that is a bit to little for building wings in moulds. I`trying to buy one of those Thomas pumps from Ebay now.
