Hallo hat schon jemand den folgenden Regler im Betrieb und kann was dazusagen??
Was meint ihr kann der Regler was und ist zu empfehlen??
Text und Foto von hobbycity.com
Ultra fast microprocessor controlled, extremely low resistance circuit and chip design, and aluminum heatsink for better thermal dissipation are just some of the features in the new TURNIGY Super Brain range of brushless speed controllers.
The Super Brain brushless esc is a high performance ESC capable of standard and competition use.
Full protection, including signal loss, over-temperature.
Programable by USB, PC or your Tx.
Compatible with all radio systems.
Features:
Supports the ‘Turnigy USB Linker’ to program the ESC by computer.
ESC Firmware upgradeable via the internet.
Integrated flight data logger, records data for the ENTIRE flight such as:
- Voltage
- Current
- Temperature
- Motor RPM
- Throttle travel
Programmable settings;
Startup (Default Standard/Soft/hard)
Low Voltage cutoff (Default 12.0/15.0/18.0/21.0/24.0/27.0/30.0/33.0/36.0V)
Current limiting (Default Standard/Very sensitive/Insensitivity/Disabled)
Brake (Default None/Soft/Hard)
PWM rate (8/12/16 KHz)
Timing (Default Auto/Low/Middle/High)
Cutoff type (Default Hard/Soft)
Governor mode (Default Auto/Low/High)
Spec.
Constant Current: 100A
Burst Current: 120A
Battery: 4-12S Lipoly
BEC: No (OPTO)
Motor Type: Brushless
Size: 69 x 52 x 24mm
Weight: 109g
Throttle range: 640us
Grüsse Norbert
Features:
- Voltage
- Current
- Temperature
- Motor RPM
- Throttle travel
Spec.
Burst Current: 120A
BEC: No (OPTO)
Weight: 109g
Grüsse Norbert
