264mm at the moment. Also you have to raise thrust tube 2cm because alignment of wing and fuselage. Mine still tends to climb with full throttle even tho elevators are trimmed 2mm nose down.
Hallo Zusammen...Der Maiden hat nun endlich statt gefunden..
Fazit:Einfach der Hammer.Fliegt wie die erste einfach nur Bombe..völlig easy und problemlos..
Bin begeistert
Bin begeistert
