Gibt es da eindeutige regeln? Nicht auf die FAI site scheint es ... Was nun ??
http://www.rcgroups.com/forums/showthread.php?p=3476201#post3476201 (weiter lesen bis unten...)
und : http://www.rcgroups.com/forums/showthread.php?t=348893
Fai:
Was macht man in so ein fall???
[ 20. März 2005, 08:21: Beitrag editiert von: Wim ]
Fai:
FAI Ciam meeting notes:5.5.6. F5D ELECTRIC POWERED PYLON RACING MODEL AIRCRAFT
5.5.6.1 General
General Rules 5.5.1. and Contest Rules 5.5.2. are applicable except where otherwise stated.
5.5.6.2 Technical Specifications
a) Model Aircraft
Minimum weight...........................1'000 g
Maximum surface loading................60 g/dm2
b) Battery
Battery is limited by either weight or number of cells.
o Maximum weight…..……425 g incl. soldering, insulations, cables and connectors.
o Maximum Number of cells....... 7
E. Giezendanner sagt es ist nicht korrekt...(duh)5.5.6 F5D ELECTRIC POWERED PYLON RACING MODEL AIRCRAFT
5.5.6.1 General
a) Model Aircraft
Maximum surface loading................65 g/dm2
b) Battery
Number of cells........................7
Type of battery.........................NiCd or NiMH
Size of cells..............................1/1 SubC
Definition of SubC size:
Maximum diameter: 24 mm
Maximum length (including pole): 45 mm
c) Each competitor may use a maximum of three model aircrafts
during the contest...
