Verkaufe wenig benutzt LiPo ladergerat Robbe Powerpeak C8 12V/22/V 1-8 LiPo.
The special advantages of the BID system:
- Simply plug the BID key into the charger and start the charge process.
- No tiresome searching through menus for the set-up parameters
- Maximum protection from mis-handling
- Storage of essential battery data in the BID chip.
- Naturally the charger can also charge batteries not fitted with the BID system.
- One BID key is supplied with the charger
Functions:
- Charge - discharge - cycle, 2 ... 99 x discharge - charge
- Adjustment of discharge - charge current, battery type and cell count.
- Display of charge / discharge time
- Display of charged-in / discharged capacity values
- Display of charge-, peak - and input voltage
- Display of discharged capacity made
- Display of individual cell voltage for lithium batteries
- Display of individual cell voltage for Lithium batteries
- USB port with boot load function
NC / NiMH-batteries
- 1...24 cells
- With automatic digital Delta-Peak cut- off circuit for NC and NiMH batteries.
LiIo, LiPo, LiFe batteries
- 1...8 cells
- Automatic cut-off using CC-CV-charge method.
Lead-acid batteries
- 1...12 cells (2...24 V)
- Automatic charge cut-off using the CC-CV charge method
Functions:
NC / NiMH-batteries
- 1...24 cells
- 1...8 cells
Lead-acid batteries
- Preis
- 69
- Zustand
- 1b
- Versandart/-kosten
- nach abfrage
- Artikelstandort
- Slowenien
