Hi all,
I'm looking for a prop shaft replacement. I think this one is bent after a the plane fell over from the table and hit the ground with the spinner, although it's not clearly visible to the naked eye, I was able to see some wobble when running the motor.
It belongs to a BOOST 60 motor from Pichler, but they seem to be out of stock with replacement parts. Any ideas where to find something that could replace this?
It's 45mm long in total, with a 6mm prop shaft diameter.
