timmybeetle
MOSEWORTH RC LiPo Battery 6S 5000mah 22.2V 60C
Specifications
Battery Type: LiPo Battery
Volts: 22.2V 6S
Capacity:5000mAh
Continuous Discharge:60C
Max Burst Rate:120C
Max Volts per Cell: 4.2V
Max Volts per Pack: 25.2V
Suggest Charge Rate: 1C
Plug Type: T, XT60, XT90, EC5, JST, TRX etc.(if you need other plug, pls give me a message in the order)
Dimensions:145*50*50mm Weight:740g
weiter lesen kann https://www.rcgroups.com/forums/showthread.php?3102250-MOSEWORTH-RC-LiPo-Battery-6S5000-60C
Piloten in Deutschland die diesem LIPO gekauft haben gerne ihre Befinden teilen, danke.
Mein test date kurz:
C = 17
Ir pro cell ist 4 mOhm
Max I = 85 Amp
Grusse Hans
Specifications
Volts: 22.2V 6S
Capacity:5000mAh
Max Burst Rate:120C
C = 17
Max I = 85 Amp
Grusse Hans
