Cohesive
Rewinding a NEU 4635 with 3 turns in a single layer. I do not need any nor do I suggest any tips for anyone. If you wanna know about availability ask NEU like it had previously been posted to READERS!
I started here with 1.7mm then realized I could fit 1.828mm. So that's where I landed.
3 turns in a single layer Delta the NEU 4635 is 635Kv.
3 (2+1) DL for 333Kv. 2x1.828mm in a delta or parallel wye it's 398 amperes Preece. In a parallel delta it is 796 amperes Preece
Thanks!
Thanks!
