Okay, the kit includes all pre-cutted balsa and plywood parts except for sheeting which is doubled (so you copy one which is already cut).
This is one example of cutting with 1.3mm "Fräser" (one german word
und mit 0.4mm Fräser....
Sperholz
And all together...
Of course you are waiting for flight report; Model needed 2 klicks of trim for elevator (down). Model flies as planned or even better than that. It's good in wind compared to Fly-Q, Sensor etc. (planes with airfoil MH32). Because of the longer nose, the model don't need any additional weight in the nose to catch CG. There is plenty of room for different components.
Plane is very manoeuvrable in air and for landings, there is no problem to land it in windy or calm weather (this is expected for competitions), and it's gliding is just perfect! You can use this plane for beginning as well, but you need to build it up fairly good, because only well build model can fly well!
Oh yes... if someone thinks wood is not strong... I can guaranteed beat someone's ass with this fuselage without breaking it
ha ha. Also, wings can hold tight loops and are almost indestructible in air. Sheeting makes them really strong!
For last thing... I'm planning the wing with ailerons as well, for those who just don't want to fly only with rudder. But I must say... in competition the simple is better!
Oh yes... this year my father (and this race was only his third) got second place with it on Slovenian F5J championship... which is amazingly good result!!!
now the discussion
