Hi all,
I have a XQ-70 ESC/BEC (https://shop.pichler.de/Brushless-Regler-XQ-70) from Pichler and I am planning to add a backup receiver battery to the system. I found that JETI DSM ESC should work to connect the ESC as input 1 and a backup battery as input 2, but there's one sentence on the JETI website (https://www.jetimodel.com/katalog/dsm-esc-dual-switch-mixer.htm) that makes me doubt the setup will work:
"The DSM ESC then automatically switches between the inputs so that your receiver is always powered by the power supply with the higher voltage."
The XQ-70 has an output of BEC = 5V / 5A and let's say I use a LiFe backup battery with 6,6V. The question is: will the JETI DSM ESC then be using the backup battery always instead of the power from the XQ-70 ESC because the battery has higher voltage?
Thanks
Thanks
