Peter vd Riet
Building Thread Weimo Raven 2.7M
As you al probably dont know. Weimo Composites has made a fress restart in building modelaircrafts. This time in Holland. The are producing giant scale airframe's from 2.7M and
bigger to a 5.2M wingspan Raven. If you would like to know more about it. I recommend you to visit there new site. www.weimo.nl
Here i wil make a building threat for my Raven 2.7M
This is what i wil use for the model.
DA 100.
KS exhaust
KS curves.
Mejzlik 28*10 2-bladed / 25 * 12s 3 blades.
Weimo enginedome, especially for DA100/DA120/DL100/Dl111.
Weimotank frame.
For power supply:
-Powerbox-Systems Powerbox Royal
-Powerbox Systems Powerbox Battery 1500 ( 2x receiver, 1x ignition)
-Powerbox-Systems Powerbox Spark Switch.
-Powerbox-Systems Powerbox Info Display.
-Powerbox-Systems Powerbox Sensor
For control:
Hitec 7955TG-2X for the stabilizer.
Hitec 7955TG-4X for the wing.
Hitec 5995TG-2X for the rudder.
Hitec 5955TG-1X for the gas control.
Futaba R6014FS 1X.
The raven is packed with new features, new developments. All parts are CNC cut.
Everything fits right out of the box''''
The raven is supplied as a ARF, but I have specially for this report, photographs of the construction process. So you can see the high quality which is used to make the raven
This is how it's gonna look.
First update wil follow soon!
DA 100.
KS exhaust
KS curves.
Weimotank frame.
For power supply:
For control:
Futaba R6014FS 1X.
