Fuel tank for F-86 air-tech (ex liebetrau)
Hello
i'm searching the kero fuel tank for air-tech f-86 (ex liebetrau) to convert my ex ICDF to turbine..
where i can find them in europe?
Thanks
Christian
in every cocacola store:D
i am flying this jet with a 2liter cola-bottle, but i dont know if sprite,fanta or 7up will do it............
Uwe
ok...i search similar fuel tank because whit this is possible to fit the inlet duct
Fuelcell
Fuelcell
Hi Christian,
in Duct-Area you are to Nosehavy. I have use 3 Dubro Fueltanks with Conversionstopper for Gas.
The two Mains ( 750 ccm ) i have left and right on the Fusewall forward the Turbine and a 300 ccm direct in middle of the two. The middle is also the Hopper. This will work good on my old one and you have no C.G. problems.
Best Regards
Peter
PS: if this solution are not okay for you , you must make Fuelcell by self
