Hallo, ich bin auf der Suche nach einer Pilotenpuppe im Maßstab 1/8 eine Büste würde auch reichen, aber leicht muss sie sein.
Gibt es da Hersteller, bei der Google Suche bin ich nicht wirklich fündig geworden.
This is a remix to create a WW1 pilot bust that could be used in RC models. This one has been used in a Sopwith Pup and a Fokker DR1 Triplane both at 1/6 scale. Using Meshmixer the base was incorporated into the body, the jacket adjusted to represent a period leather one, the pilots headphone...
I made a headset for the Gary scan here on Thingiverse. The wires are made from black wire that I curled around an allen wrench and shaped to fit. Glued with CA. Raise or lower the model in your slicer to achieve the height you need. I didn't use any support between the head and headset arch...
