Reto Schmid
Da kommt was auf uns zu....
"Regulatory framework for the operation of unmanned aircraft"
Z.b: Definition: ‘‘Unmanned aircraft (drone) means any aircraft operated or designed to be operated without a pilot on board.’
Vorgeschlagende Anpassungen der "Open Category":
CAT A0: ‘Toys’ and ‘mini drones’ < 1 kg:
Any drone sold as a toy or consumer product with a mass below 1 kg could comply with the applicable product
safety Directive and shall have limited performance to assure flight below 50 m above ground and local
operation or alternatively the means to automatically limit the altitude and the airspace they can enter.
Operation shall be performed below 50 m above ground.
CAT A1: ‘Very small drones’ < 4 kg:
Any drone sold as a consumer product which is heavier than 1 kg could comply with the applicable general
product safety Directive and shall have the means to automatically limit the airspace it can enter and the
means to allow automatic identification.
Drones operating in the ‘limited‑drone zones’ shall have active identification and up‑to‑date geo‑fencing capability
enabled.
For any operation over 50 m above ground, the pilot needs to have basic aviation awareness.
Any failures, malfunctions, defects or other occurrences that lead to severe injuries to or fatalities of any person
need to be reported.
Hoffen wir, dass das so nicht umgesetzt wird.....
Bin auf eure Kommentare gespannt.
Reto
P.S: hier gibts mehr dazu
http://easa.europa.eu/system/files/...rk for the operation of unmanned aircraft.pdf
https://easa.europa.eu/system/files/dfu/205933-01-EASA_Summary of the ANPA.pdf
enabled.
Reto
