M-346 von C&C Models
Hi all,
First sorry for not being able to do this in your language...
I sold my M346 to one of my friend after few succesful flying seasons. My advice might be out dated for someones opinnion... ignore if so :)
Mine was first M140 later M166 powered. I'd say P100 is not enough and P120 is'n fun. Y-pipe will loose some thrust into noise. It has lots of it! Trim issues discussed earlier is solvable by lifting engine and adding down trust. Throttle to elevator -mix is not the same thing IMHO... Twin engine will help here. I had issues with one engine since I was not able to lift it far enough my bottle fuel tank was above engine.
Short tail, forward CG, low thrust line compared to fuselage center and low pressure high velocity exit under tailerons means it will climb if trimmed half throttle.
I had Savox 1270 on taileron, 1258 on aileron and 1256 elsewere. Had absolutely no issues of too small torque. Taileron servo plywood plate was carbon reinforced on mine and had still some flex. 4mm carbon tubes as triangle braces solved that for good with minimal weight.
Bruno is real and good guy. Maybe he is in holidays. I contacted him by email via ccmodel. Spoke with him abaut my mods on Jetpower 2019 and got very good impression about him.
Your twin 70N sounds good to me. My Y-pipe got fractured propably by fatique cracks and mechanical resonance of center seam on groins on trousers. My engine bearers weren't glued. Just 4pc M3 bolts into fuselage formers. There is plenty of space behind main landing gear mechanism. Gear it self is bit tight into wheel well.
Hope this helps.
/Jyri
Mooney
Hello Jyri,
Thank you very much for your comments which makes the decision to use 2x Engine much easier. Your tips for building the model and also all the other hints and kinks here in this thread I will keep in mind when the time comes.
When there is interest I will follow up the build with pictures and comments.
Regards
Servus zusammen.
Wie habt ihr denn die Neutralstellung der HLW eingestellt? Gibt ja keine Markierung am Rumpf oder nen Bezugspunkt.
Andreas
Servus zusammen,
Welchen Schwerpunkt fliegt ihr jetzt?
Momentan hab ich sie auf 195mm ab vorderkante Flügel eingestellt.
Nennt mir doch mal eure Werte.
Das mit dem Schwerpunkt war ja ein großes Durcheinander bei der 346 von C&C.
Danke schonmal.
Andreas
Hallo Leute, was für ein Hammer Modell,
Würde ich mir auch zu legen wollen, scheint aber alles nicht leicht zu sein was ich hier so lese. Bin kein Profi.
Gibt's jemanden im Raum Hannover wo man sich das Modell mal angucken kann?
Ich hab den Bruno gefragt, er hat eine neue Version, noch leichter, die er selber baut.
Ich hoffe meine Kasse füllt sich noch einmal in diesen kranken Zeiten, dann wede ich zuschlagen.
Ich habe mir aus der Börse nun eine geholt.
Wahnsinn, scheint hier eine ältere Version zu sein. Die Fahrwerk Bremsen sind noch pneumatisch.
Fliegt ihr eure denn noch?
Gibt es da irgendwelche Neuigkeiten?
Es gibt ja schon bei Bruno eine neue Version, die auch rege bestellt wird.
Wo gehen die denn alle hin?
Es gibt bei Grumania ein Schubrohr, ist das besser, hat das jemand?
reicht eine 130 Turbine?
Gruß Olli
OK fährt ja nach vorne ein also 85 Grad, steht dann leicht nach vorne, sollte kein Problem sein, oder?
Also wenn die Fahrwerkschere hinten sitzt passt das Rad nicht rein, haha
Wohl verschiedene Ausführungen des Modells hier am Werk?
Das neue Fahrwerk ist nicht nach hinten versetzt, ist dies hier überhaupt das Original?
Passt so nicht.
Ajaijai, kleine Räder geht auch nicht der überstand ist zu groß
