Which is the rule or formula to set up correctly the motor timing when you've no producer advices ?
Timing must be set to get more power at a certain rpm range, to optimize efficiency. In theory when you change propeller you need also to change timing ( i.e. from a 16 x 9 to a 18 x11 as an example : rpm increase or decrease and so power must be performed to low or high rpm. correct?)
Now, if I have a 8 poles our a 2 poles motor for example and no "Auto" setting on my ESC; or what about to push power instead of rpm?
is Auto setting always a good choice ?
