Ok, I did not measure because I thought thinner were 3mm and thicker 5mm,
but now when you pointed it out, I have measured and am totally confused
I have received
balsa sheet
10x100cm : 16 x
2mm (for wing I need 12 sheets, so it would be good)
10x100cm : 7 x
3mm (for tail, rudder and horisontal?)
balsa sticks
1x1cm x100cm 2x
0.5x1cm x100cm 1x
wood sticks
1.3x1cm x 100cm 2x
0.5x1.9cm x100cm 1x
wood stick
2x3.2cm x100cm 4x (for back of a wing, trailing edge? )
1.5x3.2cm x100cm 2x (for front of wing, leading edge)
is 2mm then for main wing, will it be strong enough?
and what are all those other sticks for?
thanks a lot
maybe if it was written somewhere, people would not have to ask and bother you here
thanks
