Hey Brian,
so with the hinge you will have long joy, there is nothing warped. Especially important with a rope / spring control.
I haven't been able to find some articles in the depths of the forum. But there is always someone who knows.
I prefer to use “TESA Office” tape for the hinge. This is also available in 15mm. Before applying the tape, you should degrease the relevant areas and make sure that you do not put your fingers on the adhesive surface. Then it should last a very long time.
Have fun trying it out,
best regards Marcel
