Hallo Peter,
wenn du den apache als www-server benutzt kannst dass Passwort mit htpasswd von der shell aus bearbeiten. Genaue Infos dazu bekommst du aus den man-pages oder such einfach mal bei google nach htpasswd + apache. vielleicht hilft Dir auch das hier:
a0520@campfire$ man htpasswd
Reformatting page. Wait... done
User Commands htpasswd(1)
NAME
htpasswd - Create and update user authentication files
SYNOPSIS
htpasswd [ -c ] passwdfile username
DESCRIPTION
htpasswd is used to create and update the flat-files used to
store usernames and password for basic authentication of
HTTP users. Resources available from the httpd Apache web
server can be restricted to just the users listed in the
files created by htpasswd. This program can only be used
when the usernames are stored in a flat-file. To use a DBM
database see dbmmanage and dbmmanage.new.
This manual page only lists the command line arguments. For
details of the directives necessary to configure user
authentication in httpd see the Apache manual, which is part
of the Apache distribution or can be found at
http://www.apache.org/.
OPTIONS
-c Create the passwdfile. If passwdfile already exists, it
is deleted first.
passwdfile
Name of the file to contain the user name and password.
If -c is given, this file is created if it does not
already exist, or deleted and recreated if it does
exist.
username
The username to create or update in passwdfile. If
username does not exist is this file, an entry is
added. If it does exist, the password is changed.
SEE ALSO
httpd(8)
SunOS 5.6 Last change: February 1997 1
gruss
stephan
