I have about 20 flights on my RCFree. I'm using the Evo Backpack and have put the bar on the 1st set of holes on the frame. (1st set of holes at the front if facing from the front).
I fly anywhere from 1.6 - 2kg depending on the wind. I've noticed that at times it's very hard to get altitude. To get to 300 feet it can sometimes take 4-5 minutes. Is this normal or might i have a setting that is not correct.
If i fly slowly infront of me, I can sometimes see that there is a little loose in the brake lines. Are they supposed to be tight?
thanks
charles
thanks
charles
