Sorry for not using german; if I find a translater I'll post it again in german ; Answers welcome in german too; reading it is not a problem.
Hi ,
I want to verify my TX frequency.
I have a HP spectrum analyser which I can use.
As the signal send by my radio is modulated, it both sends the Xtal base tone (in my case 35.030Mhz) and the down shifted frequency
(as our RC FM is basically FSK, frequency shift key).
My questions :
-how much does a Futaba radio shifts down (negative shift keying) ?
-how precise should my frequency be ? How many ppm may it be off ?
-Would it better to "kill" the LF-signal to get a proper measurement ? (disconnect from HF-part)
-I measure "true air"; is it better to directly connect the spectrumm analyser to the radio ? If so, how ?
-Is a spectrum analyser (calibrated HP8691A) good enough to get a correct freq. measurement ? Wouldn't a counter be better ? Is so , how to connect to the HF-part of the radio ?
-If one changes channel ; is it needed to have the HF part recalibrated ? Is yes, what is tuned again ? Only the 2 frequencies or also other things ? Is so, what ?
-Tuning the HF , Is this something I can do myself using the spectrum analyser ? Do I need other things to ? Which ? What other parameters need to be checked/set apart from the frequencies ?
All inputs welcome .
Please no reactions on the legal aspects; I'm only interrested in the technical matter.
For your info, I'm familiar with electronics (engineering degree) but have not much experience in RF.
thanks,
Rob.
Hi ,
My questions :
thanks,
Rob.
