trying to decipher your note: (Winding scheme 1-3-2-5-4-7-6-9-8-10-11) but having a little trouble understanding.
any assistance would be appreciated.
YY ABCABC / ABCABC 4T was scheme I was planning to use but find that the Kv value falls a little too high from target 1100 and 5 turns a little too low. The half turn 4.5 would work much better.
It's easy, if you know what to do
Start with Wire #1 and wind the first Tooth with 4 turns. Then take Wire #3 and make another 4 turns on tooth 3, so you can wind very easy because you have the Space you need for your tools. As soon as this two are finished, take wire #2 and wind tooth 2 again with 4 Turns. After that the beginning and ends of the Wires are all on the same side. This was the first ABC (except of the half winding)
Now take the end of wire #2 and make the half winding, you'll have to push it through between the other wires. Make sure to smoothen the Ends of the wire or you'll scratch the insulation of the other wires.
With wire #2 on the other side now, you jump to tooth 5 and make the next 4 windings (you see the half is missing again
). Continue with wire #1 make the half winding, jump to tooth 4 make 4 turns and this time you can finish it complete and add the half.
Now you have tooth 1,2 and 4 finished complete. Go further with tooth 7 and Wire #1 of the second motor, if this is finished take wire #3 make the half turn and jump to tooth 6 finish the first motor with the last 4,5 windings.
Continue in the same way with motor #2 and always be careful with scratches on the wires.
I've made a nice Picture (the last half hour
) hope it helps to understand
P.S.: It is helpful to do a "dummywinding" on tooth 12 to fix the wire on tooth 1
Greez
EDIT: Winding above looks like my motor
Winding like this looks better and you'll get shorter transitions
