I finished the Precision 2 - F3G today.
As already mentioned, things were very tight in the hull. The REX 10 assist receiver only fits standing in front of the connector. I installed it with the antennas facing the front, all the servo cables go to the rear and are squeezed into the area under the connector (see pictures).
At the front, the Tenshock EDF 1520 - 11T - 4-pole 3800KV motor with Micro Edition 5:1N is mounted as usual without any problems (30mm template drilled to fit, stick flush to the fuselage frame, drill holes and countersink) - then the VM Pro 30mm spinner fits perfectly. The YGE 65 LVT comes very close behind the engine - mounted on the underside because of the canopy.
The SLS Xtron Competition 4S - 900mAh battery fits just between the controller and the receiver.
I liked using it because of its low height. It is practically impossible to accommodate a backup battery.
Best regards
Michael
Anhang anzeigen 12705571Anhang anzeigen 12705572Anhang anzeigen 12705573Anhang anzeigen 12705574Anhang anzeigen 12705575Anhang anzeigen 12705577
Tomorrow we'll have our first flight and then I'll post pictures of the entire model. If it had rained today, the pictures would have been nothing
