Just to make sure, again, this is for identical groups, not for the other scheme you were using before.
Wind Teeth 1-6, use start/end/start wires from group 1/2/3 as first Wye (star) terminal.
Use the other three as the three motor terminals.
Then on the second half (Teeth 7-12), use end/start/end from group 1/2/3 of that motor for the second Wye terminal and again the other 3 as the motor terminals.
Finally, when you combine the two halves, use both motor terminals from group 1 (they will be on opposite sides of the stator!) as the first combined motor terminal, same for the other two.
So combine end of group 1/first partial motor with start of group 1/second partial motor into the first combined terminal and so on.
Yes, there is a detailed (german) writeup about this on powercroco.de - but basically, that's about it.
http://www.powercroco.de/schemamodus12N_YY2.html
Regards,
Simon.
Regards,
Simon.
