Beschreibung nun da, jedoch probleme beim Programmieren, erneute Hilfe erforderlich..
Habe nun eine Beschreibung erhalten und stelle sie mal rein, falls diese wieder wer sucht.
Habe noch ein Problem, Regler lässt sich nicht programieren. Habe alles versucht, er beginnt nach ein paar sekunden eine Melodie 10 mal zu spielen und wiederholt diese nach ein weiteren paar sekunden. Egal wie die Gas Stellung des Knüppels ist...
RC Smart
Introduction of the Brushless Motor Speed Controller
Type RC Smart 100A ESC
Sustaining Voltage 6 - 30V 2-8 LIPO / 4 – 25 NIMH
BEC Current 3A
Continuous Output Current 100A
Instant Max Current 110A / 12s
Inside Impedance 0.0022©
Reversion Yes
Low Voltage, Cut Electricity Protection Yes
Size 71.5mm x 39.8mm x 17.8mm
Weight (approximately) 89g
Wiring Diagram:
Phrase 1 Enter programming Mode:
1. Connect your and receiver to the speed controller, but do not connect the battery yet.
2. Turn on your transmitter and move the throttle stick the full throttle position (full up).Please Note: Most Futaba transmitters have the throttle channel reversed by default.
3. Connect your battery and the controller will initialize with a musical tone.
Phrases 2 Programming:
After 3 seconds, the controller will start beeping of tones- a musical tone followed by one or more beeps. Each sequence represents a parameter that you can program and is repeated 3 times. The parameters are:
j– Music Tone+1 Beeps Options 1.Cell Type and No. of Cell
j–– Music Tone+2 Beeps Options 2.throttle Setting
j––– Music Tone+3 Beeps Options 3 Bake Setting/Throttle type (for Heli).
j–––– Music Tone+4 Beeps Options4. Direction and Cutoff Type
Step 1: Starting, Enter Sub-options. When your hear the sequence for the parameter you wish to program, move the throttle stick to the Center Position to Enter Sub-options.
The controller will the start beeping a Morse code sequence of short and long beeps representing the possible options you may choose for the selected parameter. See table 2 for a list of all programmable options. Each option sequence is repeated 3 times.
Step 2: Select and save, the select the option, move the throttle stick back to the Full-up-position. When you hear the sequence for the option you wish to select. The controller will then save the selected option, and sound a long beep as a confirmation. It then goes back to the beginning of programming sequence (phrases 2).
Step 3: Complete programming and save options. Setup all parameters you need to change. When complete, move the throttle stick to the Lowest (down) Position. The controller will save all options and re-initialize in normal running mode so you can start your motor.
The table below summarizes the various programming options for each parameter: *Is Default Setting
1. music– For (2S-7S)- ESC Cell Type and Number of Cell
'–1 Short + 1 Long NiMh /NiCD Auto cell Count – 0.8V/Cell Cutoff Voltage
'––1 Short + 2 Long 7S Li-Po (25.9V)- 21V Cutoff Voltage
'–––1 Short + 3 Long 6S Li-Po (22.2V)- 18V Cutoff Voltage
'––––1 Short + 4Long 5S Li-Po (18.5V)- 15V Cutoff Voltage
'–––––1 Short + 5 Long 4S Li-Po (14.8V)- 12V Cutoff Voltage
'––––––1 Short + 6 Long 3S Li-Po (11.1V)- 9V Cutoff Voltage
'–––––––1 Short + 7 Long 2S Li-Po (7.4V)- 8V Cutoff Voltage
2. Throttle Setting j– –
''– 2 Short +1 Long Auto Throttle Range *
''––2 Short +2 Long 1.1ms to 1.8ms
''––––2 Short +3Long Hard start *
''–––––2 Short +4 Long Soft start
3. Brake setting(for normal Aircraft) j– – –
'''–3 Short + 1 Long No Brake
'''–– 3 Short + 2 Long Soft Bake*
'''–––3 Short + 3 Long Medium Brake
'''–––– 3 Short+ 4 Long Hard Bake
4. Direction and Cutoff Type j– – – –
''''– 4 Short +1 Long Clockwise Rotation*
''''–– 4 Short +2 Long Counterclockwise Rotation
''''––– 4 Short +3 Long Soft Cutoff
''''–––– 4 Short +4 Long Hard Cutoff*
