Hallo Namenloser!
Hatte vor Jahren auch mit dem ST4500 und ST3000 einige Anfangsschwierigkeiten.
Hilfreich war dies:
Prop 22x10 Menz S
ST4500 successfully for years in scale airplane fantastic power and reliability.
Make sure you don't run to much oil, I have always run cool power syn at 12% and no nitro. starting has always been very easy. BTW I run on board glow that comes in at 1/4 throttle to keep the fire burning.
Tigers are usually run on 10-12% oil and either 0 or 5% Nitro. You are not going to fix the deadstick issue on a 3D plane without a fuel pump, I have tried Perry's before, no luck. One thing you might want to look into is the Cline regulator system, lotta guys with Moki's use it, although my Moki ran great by itself. I personnaly would not use a glow motor on a 3D plane(except a YS of course), you are asking for trouble, one of the benefits of gas is the pumper carb. You might try an OS 4-stroke plug, most guys I know use em in the bigger motors, Tigers, OS BGX, Moki's, etc.
The type F plug is your best choice. I've always put an "on board glow" on my big singles, it seems like the idle was always hard to maintain throughout the flight. I'm sure it was a tuning problem on my part, but the glow kept me from deadsticking while the motor was being broke in. I don't know how old your 4500 is, but you might want to try it to see if it works.
If your motor is dying when you bring it to idle, you might be a little lean on the low end, it's hard to say without listening to it.
this engine was built in Italy and made to run with no nitro and 10% oil
my own fuel 5% nitro 10% super techniplate oil and the rest 85% methanol"
Supertigre ab 20ccm sollten nicht mit mehr als 10% Öl und vor allem ohne Nitromethan betrieben werden.
Mit mehr Öl ist die Gemischregulierung nicht mehr mager genug ein zu stellen das sie Gas annehmen und immer noch "fett" Genug im Vollgas laufen.
Überhitzungen oder extrem schlechte Gasannahme verbunden mit hohem Spritverbrauch sind die Folge.
Meine laufen mit 8% Aerosynth 3, Rest Methanol, kein Nitromethan ohne jedes Problem, ohne stottern im Gasübergang und mit gehörig Leistung.
Z.B. mein St 3200 dreht mit Krummscheid Rohr eine 22x8 Kohlefaser Latte mit satten 7800 U/min. Mein St2300 mit einer 18x8 Kohlefaserlatte und Krummscheid Rohr 7900-8000 U/min.
Bei beiden Motoren ist das Ansprechverhalten auf ein Resorohr extrem gut und die Leistungsausbeute vorher/nachher sehr hoch.
Am 2300 sind es gemessen zwischen 800 und 1000 U/min Unterschied zu einem Schalldämpfer bei gleichem Prop und Sprit. "
Gruß Peter
