Ville
Please, can anyone help me with this problem? I tried to install my Weatronic 2.4 GHz DV4 module in Multiplex Royal MC but it does not work. It is no problem to use Weatronic in my Royal Modul. Both transmitters talk PPM, so maybe it should work in Royal MC as well, or is it something I miss?
The advantage of using Weatronic is that I can set, for example, servo travel, endpoints, failsafe via the Giga Control configuration program.
I have set the Royal MC up for PPM, see picture. The original 40 MHz transmitter module works ok with both PPM and PCM receivers.
The Weatronic 2.4 GHz works perfectly on all my other TX, Royal Pro/SX, P4000, Royal Modul.
I have tried all modulation settings in the GigaControl.
Remember that I jumper pins 2 and 5 when I converted a Royal Pro for the first time, (long time ago) with Jeti TU module.
What if I remove the resistor on the Weatronic module connector? I'm grabbing the last straws now, as perhaps the last resort ...
Would love to make the Weatronic modules work, would be worth gold.
Thanks in advance!
/Ville
Thanks in advance!
/Ville
