F5J Regelwerk
F5J Regelwerk
Meine Herren,
Nächsten Monat wird bei der CIAM plenary meeting unterstehendes Regelwerk zur Abstimmung eingereicht werden
5.5.10.1 Definition
This contest is a duration and landing event.
5.5.10.2 Model Aircraft Specifications
Maximum Surface Area 150 dm2
Maximum Flying Mass 5 kg
Loading 12 to 75 g/dm2
Type of Battery .LiPo
Limitation of Energy 200 Watt-min
5.5.10.3 Duration and Landing Task
a) This task must be completed within 600 seconds after the model releases hand-launched and ends, when the model airplane comes to rest after landing.
b) The competitor has to decide how much and how often he will switch on the motor.
c) Gliding time is cumulative and one point will be awarded for each full second the model aircraft is gliding;
d) One point will be deducted for each full second flown in excess of 600 seconds.
e) Additional points will be awarded for landing; when the model aircraft comes to rest in the 30 m circle, 10 points will be given while coming to rest in the 20 m circle gives 20 points, and when coming to
rest in the 10 m circle 30 points will be given. The distances are measured from the centre of the circle to the nose of the model aircraft.
f) No additional points will be awarded if the landing occurs more than 630 seconds after beginning of this task.
Mit freundlichen Grüssen,
Robert Hermens
