Using the equipment you mentioned, how much lead was used and where was it placed? Can you share a picture of your actual plane and motor install? What is your planes total weight? Thank you.
I User 10 Grams of led at the tail. The Battery is so far as possible backwards in the fuselage. I mailed with CLM and they told me the next generation of fuselages will have a shorter nose.
